[postgis-devel] [PostGIS] #1631: SQL/MM Spatial exception - start node not geometry start point
PostGIS trac at osgeo.org
Wed Feb 29 02:16:03 PST 2012
 Reporter:  3nids     |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  2.0.x
 Keywords:            |
 Running the same demo set as fot ticket 1613, produces the following
 error:
 psql:strk.demo.sql:18: ERROR:  SQL/MM Spatial exception - start node not
 geometry start point.
 CONTEXT:  SQL statement "SELECT ST_ChangeEdgeGeom(atopology, rec.edge_id,
 snapedge)"
 PL/pgSQL function "topogeo_addpoint" line 83 at PERFORM
 PL/pgSQL function "topogeo_addlinestring" line 111 at assignment
 SQL statement "INSERT INTO test_topo.relation(topogeo_id, layer_id,
 element_type, element_id) SELECT 2, 1, 2,
 topogeo_addLineString('test_topo',
 '0102000020155500000B000000BAF06A7E96F92041CD9B5862AAAF01417C5F9E5897F92041C5021D65AAAF0141713D0A57BDF920415C8FC2F5B4AF01411F85EB51D7F92041F6285C8FB8AF014148E17A142CFA2041C3F5285CC1AF0141F6285C8F3AFA2041B81E85EBC7AF0141AE47E1FA50FA204166666666C6AF01415CA1BCED53FA2041A41C48D6C8AF014148E17A1460FA204114AE47E1D2AF0141D1AC322684FA2041A3ECA94C02B001418FC2F5A895FA2041D7A3703D1AB00141'::geometry,
 0);"
 PL/pgSQL function "totopogeom" line 116 at EXECUTE statement
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1631>
