[postgis-devel] [PostGIS] #1631: SQL/MM Spatial exception - start node not geometry start point
PostGIS trac at osgeo.org
Wed Feb 29 02:36:46 PST 2012
 Reporter:  3nids     |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 Didn't check yet but I suspect ST_Snap snapped the first point of the edge
 rather than snapping the first segment. Re-adding the first point might
 fix this case.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1631#comment:3>
