[postgis-devel] [PostGIS] #1637: rtpostgis_upgrade_20_minor.sql doesn't work
PostGIS trac at osgeo.org
Wed Feb 29 05:27:33 PST 2012
 Reporter:  nicklas                |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Changes (by strk):
  * owner:  pramsey => strk
  * version:  1.5.X => trunk
  * component:  postgis => build/upgrade/install
Comment:
 Did you install postgis with "create extension" ?
 I suspect in that case the correct way to upgrade would be trough the
 extension mechanism as well (not that I think it would work)
 The dependency of postgis ON raster does sound bogus, btw.
 Could be due to the fact that the so-called "postgis extension" includes
 raster, which is kind of puzzling.
 I'd leave this to the ones who thought keeping "core" and "raster"
 extensions together was a good idea...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1637#comment:1>
