[postgis-devel] [PostGIS] #1637: rtpostgis_upgrade_20_minor.sql doesn't work
PostGIS trac at osgeo.org
Wed Feb 29 05:28:57 PST 2012
  Reporter:  nicklas                |       Owner:  strk
      Type:  defect                 |      Status:  closed
  Priority:  medium                 |   Milestone:  PostGIS 2.0.0
 Component:  build/upgrade/install  |     Version:  trunk
Resolution:  invalid                |    Keywords:
Changes (by robe):
  * status:  new => closed
  * resolution:  => invalid
Comment:
 Nicklas,
 Nice to see you back in the groove again :).
 As strk said sounds like your postgis was installed with extensions.  You
 can't upgrade an extension installed postgis with the scripts, you have to
 use
 ALTER EXTENSION postgis  UPDATE TO ..
 http://www.postgresql.org/docs/devel/static/sql-alterextension.html
 Sadly extension updates have to be done at version milestones since your
 from and to can't be the same version so you'll need to wait till pramsey
 releases the next release today.
 However that said -- there is an issue with the update scripts for
 extension which I have noted in http://trac.osgeo.org/postgis/ticket/1630
 which I hope to fix before beta comes out today.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1637#comment:2>
