[postgis-devel] [PostGIS] #1634: Output confused for the function postgis_full_version()
PostGIS trac at osgeo.org
Wed Feb 29 07:50:59 PST 2012
  Reporter:  lrssvt   |       Owner:  pramsey
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  2.0.x
Resolution:           |    Keywords:
Changes (by strk):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 How did you obtain your sources ?
 Does the postgis_svn_revision.h contain a sensible revision number ?
 Does it get updated on "make postgis_svn_revision.h" ?
 Did you make install ?
 Did you load postgis_upgrade_20_minor.sql ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1634#comment:3>
