[postgis-devel] ERROR: SQL/MM Spatial exception - geometry crosses an edge
Salvatore Larosa-1 s_larosa at libero.it
Wed Feb 29 10:50:44 PST 2012
I was trying to construct the topology for a set of polygonal data type and
i get this error:
SQL state: P0001
Context: PL/pgSQL function "topogeo_addlinestring" line 143 at assignment
SQL statement "SELECT array_cat(edges, array_agg(x)) FROM ( select
topology.TopoGeo_addLinestring(atopology, rec.geom, tolerance) as x ) as
foo"
PL/pgSQL function "topogeo_addpolygon" line 23 at assignment
@strk surely know where you get your hands!
More info in annexes!!
http://postgis.17.n6.nabble.com/file/n4532494/prov.sql prov.sql
http://postgis.17.n6.nabble.com/file/n4532494/provTopo.sql provTopo.sql
View this message in context: http://postgis.17.n6.nabble.com/ERROR-SQL-MM-Spatial-exception-geometry-crosses-an-edge-tp4532494p4532494.html
Sent from the PostGIS - Dev mailing list archive at Nabble.com.
