[postgis-devel] [PostGIS] #1425: shp2pgsql-gui won't let overwrite geom
PostGIS trac at osgeo.org
Sun Jan 1 22:18:23 PST 2012
 Reporter:  robe           |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  low            |   Milestone:  PostGIS 2.0.0
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
 Just tried loading a shapefile with the shp2pgsql-gui.  I seem to be able
 to overwrite all the other settings except the geometry_column one is
 stuck at geom and any attempt to overwrite it -- say changing to geog it
 reverts as soon as I leave the field.
 Though this may just be a display issue (or perhaps it defaults to geog if
 I then check geography though it doesn't display geog).  Anyrate the
 column did end up being named geog but the display was confusing.  I'll
 retest this later by changing to something other than geom/geog
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1425>
