[postgis-devel] Vote on Merging postgis and raster installs and when
Sandro Santilli
strk at keybit.net
Mon Jan 2 01:26:48 PST 2012
To add more to the discussion, here's a brief overview of what we have.
1) dynamic libraries containing C-level stored procedures
a) postgis - the core
b) raster (depends on 1.a? depends on 2.a?)
2) SQL files enabling functions in the dynamic libraries
a) postgis (depends on 1.a)
b) raster (depends on 1.b, maybe also on 2.a)
3) SQL files containing pure scripting level functions
a) topology (depends on 2.a)
Currently the default install only installs the core library and enabler
script (1.a and 2.a). It is possible to also install raster (1.b and
2.b) passing --with-raster to the ./configure script and to also install
topology (3.a) passing --with-topology to the ./configure script.
--strk;
On Mon, Jan 02, 2012 at 10:16:07AM +0100, Sandro Santilli wrote:
> On Mon, Jan 02, 2012 at 01:36:13AM -0500, Paragon Corporation wrote:
> > Do we want to do this. We said we did at the code sptring. Are we ready?
> > The main reason we had kept the installs separate is because building with
> > raster was much harder because of the python dependency. Now that python is
> > no longer required and compiling GDAL is not that big of a deal (and in fact
> > something the postgis geometry/geography might find useful alter on) , can
> > we merge?
> > +1 from me
> > Granted I don't know how much effort is involved. Right now the
> > extensions/postgis folder does have them merged
> > So when you do CREATE EXTENSION postgis; or ALTER EXTENSION postgis UPDATE
> > TO "2.0.0a13";
> > You get both postgis geometry/geography and raster support and update both
> > postgis geometry/geography/raster
> > So it's just the old way of installing postgis that is still separated.
> > This of course also requires that Chris works out the builbot issues with
> > why topology and raster aren't being tested.
> I'm not a big fan of monolithic systems.
> What's the rationale for forcing anyone who only needs vectors to also have
> support for rasters ?
> Seems more of a packaging issue to me, and I see packagers usually do more
> splitting than upstream (breaking packages in -core, -dev, -utils, -doc, ...)
> --strk;
> ,------o-.
> | __/ | Thank you for PostGIS-2.0 Topology !
> | / 2.0 | http://www.pledgebank.com/postgistopology
> `-o------'
,------o-.
`-o------'
