[postgis-devel] [PostGIS] #1426: OGR2OGR fails importing data to postgis
PostGIS trac at osgeo.org
Mon Jan 2 08:51:29 PST 2012
 Reporter:  anguscarr        |       Owner:  pramsey
     Type:  defect           |      Status:  new
 Priority:  low              |   Milestone:  PostGIS 2.0.0
Component:  postgis          |     Version:  1.5.X
 Keywords:  ogr2ogr, import  |
 When I run ogr2ogr, I get:
 C:\Temp>"c:\program files\gdal\ogr2ogr" -f "PostgreSQL" PG:"host=127.0.0.1
 user=apc dbname=FMP port=5433"
  -nln black_spruce_2011.aoc01 c:\temp\tmpsqqk3e PAL
 ERROR 1: AddGeometryColumn failed for layer black_spruce_2011.aoc01,
  layer creation has failed.
 ERROR 1: Terminating translation prematurely after failed
 translation of layer PAL (use -skipfailures to skip errors)
 I had a look into the DB logs, and got this:
 ERROR:  cannot delete from view "geometry_columns"
 HINT:  You need an unconditional ON DELETE DO INSTEAD rule or an INSTEAD
 OF DELETE trigger.
 STATEMENT:  DELETE FROM geometry_columns WHERE f_table_name =
 'aoc01' AND f_table_schema = 'black_spruce_2011'
 ERROR:  current transaction is aborted, commands ignored until end of
 transaction block
 For the short term, I added this rule:
 CREATE OR REPLACE RULE ogr2ogr_delete_problem AS
         ON DELETE TO public.geometry_columns
         DO INSTEAD NOTHING ;
 Obviously, that's not a long-term solution, but I don't think I should fix
 it without looking to the larger community. I assume this is an OGR2OGR
 bug, but since my fix of the day is on my DB, I thought I would post here.
 Is it safe to leave this rule in place for the long term?
 Right now, I am loading data into an empty db, and it's ok for now.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1426>
