[postgis-devel] Vote on Merging postgis and raster installs andwhen
Chris Hodgson chodgson at refractions.net
Tue Jan 3 08:23:43 PST 2012
If I (or my packager) compile postgis without raster support, and I
install it and have data in it, can I add raster support to it later -
without dumping all my data? I think I can with a separate
postgis-raster extension. Is it possible with everything in one
extension? Might be a useful case to support... I can see the case for
monolithic packaging as well though.
Chris
On 12-01-02 09:06 AM, Paragon Corporation wrote:
> strk,
> I'm fine with raster and topology being dis-abable, but I think the default
> should be they are automatically installed and you have to do an explicit
> w/out to not get them.  Since topology is in its own
> schema -- it has to be a separate extension.  For raster -- I need to know
> if people feel this should stay separated as like I said --
> that means I have to break it back out as its own extension.
> For topology there is no extra dependency (except possibly for it needing
> GEOS 3.3 or higher, but like I said I think its pretty stupid we don't
> require GEOS 3.3 for PostGIS 2.0.0 or at least have a glaring wanrning you
> need to do a w-out 3.3 to get past). So there really is no excuse for it not
> being turned on by default.
> I don't think packagers necessarily leave these things out or use lower
> versions that don't have all features enabled, I think we put them in that
> trap
> by not warning them they are missing things. After all they package for a
> lot of things not jsut PostGIS and I know as a packager its hard. As a
> PostGIS user things being left out really frustrates me which is one reason
> I can see why some windows users are afraid of using Linux.
> Thanks,
> Regina
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On
>> Behalf Of Paragon Corporation
>> Sent: Monday, January 02, 2012 11:38 AM
>> To: 'PostGIS Development Discussion'
>> Subject: Re: [postgis-devel] Vote on Merging postgis and
>>> I'm not a big fan of monolithic systems.
>> I am -- I hate stuff I can't count on not being there
>> especially if I don't have the ability to compile my own.
>> E.g. it drives me nuts when the packager decides to package
>> an antiquated GEOS and half the things I need are disabled as
>> a result. The same I see with raster.
>>> What's the rationale for forcing anyone who only needs
>> vectors to also
>>> have support for rasters ?
>>   Even for projects I won't really need core raster for, I
>> plan to use it for in the database reporting -- e.g.
>> outputting geometries in my report writer without need for
>> extra mapping software.
>>> Seems more of a packaging issue to me, and I see packagers
>> usually do
>>> more splitting than upstream (breaking packages in -core, -dev,
>>> -utils, -doc, ...)
>> Well - I need to know now.  Because when I had raster as a
>> separate extension, I distinctly remember Paul saying -- "Why
>> don't you have it as part of postgis extension?"
>> So I merged them.  I can't have some postgis 2.0.0 extensions
>> having raster support and some not. Since an extension is
>> more than packaging.  It means -- these are the functions you
>> have -- no pick and choose.  If it is then it has to be a
>> separate extension.
>> For PostGIS 2.0.0 -- raster is a big piece of it.  It would
>> be a shame for people to not get vector support just because
>> their package manager felt they didn't need it.  Trust me
>> there will be some of those and it will be the same annoying
>> issue I have to deal with when I have to compile my own
>> PostGIS  because the packager decided I didn't need all my
>> functions and gave  me a half-assed version of GEOS.
>> Thanks,
>> REgina
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
