[postgis-devel] Raster Regress
Paragon Corporation lr at pcorp.us
Tue Jan 3 22:44:52 PST 2012
Could it be the GEOS version?
I'm running GEOS 3.3.2dev, GDAL 1.9.0rc1, Proj 4.6.something on windows
(mingW compiled) and my raster tests pass (8.4, 9.0, 9.1).
I see though that Paul is running GEOS 3.2.4 (fairly antiquated I would say
Thanks,
Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Bborie Park
> Sent: Wednesday, January 04, 2012 12:53 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Raster Regress
> I've run regression tests using the following:
> All test boxes have the following in common:
> PROJ4 4.7.1
> GEOS 3.3.1
> GDAL-svn r23698
> PostGIS-svn r8668
> Slackware Linux 13.37
> 	PostgreSQL 9.1.2 = OK
> 	PostgreSQL 9.0.6 = OK
> 	PostgreSQL 8.4.10 = OK
> Slackware64 Linux 13.37
> OSX 10.6.8 64-bit
> I'll run a series of tests varying the GDAL version though I
> don't think that could be causing the regression failures as
> ST_BandMetadata and 2-raster ST_MapAlgebra variants do not
> use GDAL in any way.
> -bborie
> On Tue, Jan 3, 2012 at 4:29 PM, dustymugs <dustymugs at gmail.com> wrote:
> > Paul,
> > Yes.  Raster is supposed to have zero failures.  I'll fire
> up and test
> > my OSX VM when I get the chance.  My OSX VM does use different
> > versions of GEOS
> > (3.3.1) and GDAL (trunk) though.
> > -bborie
> > On 01/03/2012 04:26 PM, Paul Ramsey wrote:
> >> Kind of a re-run from earlier, but is raster supposed to regress
> >> clean? This is what I get...
> >>  PostgreSQL 9.1.2 on x86_64-apple-darwin10.8.0, compiled by
> >> i686-apple-darwin10-gcc-4.2.1 (GCC) 4.2.1 (Apple Inc. build 5666)
> >> (dot 3), 64-bit
> >>  Postgis 2.0.0SVN - 2012-01-04 00:21:04
> >>    GEOS: 3.2.4-CAPI-1.6.4
> >>    PROJ: Rel. 4.7.1, 23 September 2009
> >>    GDAL: GDAL 1.8.1, released 2011/07/09
> >> Running tests
> >>  check_raster_columns .. ok
> >>  check_raster_overviews .. ok
> >>  rt_io .. ok
> >>  rt_bytea .. ok
> >>  box3d .. ok
> >>  rt_addband .. ok
> >>  rt_band .. ok
> >>  rt_asgdalraster .. failed (diff expected obtained:
> >> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_8_diff)
> >>  rt_astiff .. failed (diff expected obtained:
> >> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_9_diff)
> >>  rt_asjpeg .. failed (diff expected obtained:
> >> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_10_diff)
> >>  rt_aspng .. failed (diff expected obtained:
> >> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_11_diff)
> >>  rt_union .. ok
> >>  create_rt_properties_test .. ok
> >>  rt_dimensions .. ok
> >>  rt_scale .. ok
> >>  rt_pixelsize .. ok
> >>  rt_upperleft .. ok
> >>  rt_rotation .. ok
> >>  rt_georeference .. ok
> >>  rt_set_properties .. ok
> >>  drop_rt_properties_test .. ok
> >>  create_rt_empty_raster_test .. ok
> >>  rt_isempty .. ok
> >>  rt_hasnoband .. ok
> >>  drop_rt_empty_raster_test .. ok
> >>  rt_metadata .. ok
> >>  create_rt_band_properties_test .. ok
> >>  rt_band_properties .. ok
> >>  rt_set_band_properties .. ok
> >>  rt_summarystats .. ok
> >>  rt_count .. ok
> >>  rt_histogram .. ok
> >>  rt_quantile .. ok
> >>  rt_valuecount .. ok
> >>  rt_valuepercent .. ok
> >>  rt_bandmetadata .. failed (diff expected obtained:
> >> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_36_diff)
> >>  rt_pixelvalue .. ok
> >>  drop_rt_band_properties_test .. ok
> >>  rt_utility .. ok
> >>  create_rt_mapalgebra_test .. ok
> >>  rt_mapalgebraexpr .. ok
> >>  rt_mapalgebrafct .. ok
> >>  rt_mapalgebraexpr_2raster .. failed (diff expected obtained:
> >> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_43_diff)
> >>  rt_mapalgebrafct_2raster .. failed (diff expected obtained:
> >> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_44_diff)
> >>  drop_rt_mapalgebra_test .. ok
> >>  create_rt_mapalgebrafctngb_test .. ok
> >>  rt_mapalgebrafctngb .. ok
> >>  rt_mapalgebrafctngb_userfunc .. ok
> >>  drop_rt_mapalgebrafctngb_test .. ok
> >>  rt_reclass .. ok
> >>  rt_resample .. failed (diff expected obtained:
> >> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_51_diff)
> >>  rt_asraster .. failed (diff expected obtained:
> >> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_52_diff)
> >>  rt_intersection .. failed (diff expected obtained:
> >> /var/folders/vQ/vQpcmrOZEXuINbyg+7Jj4k+++TI/-Tmp-//test_53_diff)
> >>  create_rt_gist_test .. ok
> >>  rt_above .. ok
> >>  rt_below .. ok
> >>  rt_contained .. ok
> >>  rt_contain .. ok
> >>  rt_left .. ok
> >>  rt_overabove .. ok
> >>  rt_overbelow .. ok
> >>  rt_overlap .. ok
> >>  rt_overleft .. ok
> >>  rt_overright .. ok
> >>  rt_right .. ok
> >>  rt_same .. ok
> >>  drop_rt_gist_test .. ok
> >>  rt_spatial_relationship .. ok
> >>  rt_intersects .. ok
> >>  rt_samealignment .. ok
> >>  bug_test_car5 .. ok
> >>  uninstall ... failed (Count of object before install
> (3855) != count
> >> after uninstall (3872))
> >> _______________________________________________
> >> postgis-devel mailing list
> >> postgis-devel at postgis.refractions.net
> >> http://postgis.refractions.net/mailman/listinfo/postgis-devel
