[postgis-devel] [PostGIS] #1424: tickets error on check phase
PostGIS trac at osgeo.org
Wed Jan 4 00:54:41 PST 2012
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  postgis    |     Version:  trunk
 Keywords:             |
Comment(by aperi2007):
 Actully my settings for compile on RH 64bit are these:
 CFLAGS="-m64" CPPFLAGS="-m64" CXXFLAGS="-m64" LDFLAGS="-m64" FFLAGS="-m64"
 LDFLAGS="-L/usr/lib64/" ./configure --with-
 pgconfig=/usr/local/pgsql/bin/pg_config --with-geosconfig=/usr/local/bin
 /geos-config --with-projdir=/usr/local/share/proj --with-
 xsldir=/usr/share/sgml/docbook/xsl-stylesheets-1.75.2 --with-
 libiconv=/usr/bin --with-xml2config=/usr/bin/xml2-config --with-gui
 --with-topology=yes --with-gdalconfig=/usr/local/bin/gdal-config --with-
 raster=yes --with-jsondir=/usr/local/lib
 and
 gcc: 4.4.6 20110731 (Red Hat 4.4.6-3)
 Now I'll try using a more simply version of settings.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1424#comment:4>
