[postgis-devel] [PostGIS] #1424: tickets error on check phase
trac at osgeo.org
Wed Jan 4 06:47:31 PST 2012
Reporter: aperi2007 | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by robe):
hmm but that doesn't explain why Hudson wasn't registering errors either
and I think its running red-hat though might be running a 32-bit. For the
experimental I haven't updated that since my last sweep of cleanup so you
might be testing against a newer Linux build. Was waiting till we call
Alpha or by Friday whichever comes first before I release the next
experimental build.
Windows shouldn't be anymore case insensitive for string compare than
redhat unless there is a switch somewhere turned on causing it.
strk,dustymugs,pramsey -- are you noticing any regress failure with
regular postgis regress?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1424#comment:9>
