[postgis-devel] [PostGIS] #1432: [RASTER] segfaults on regression testing with --enable-cassert
PostGIS trac at osgeo.org
Thu Jan 5 11:06:41 PST 2012
  Reporter:  strk            |       Owner:  dustymugs
      Type:  defect          |      Status:  new
  Priority:  critical        |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:                  |    Keywords:
Comment(by robe):
 Bborie,
 I wonder if this will fix the crashing issue I was experiencing with my
 garden tests that you couldn't repelicate. That is almost always crashed
 on ST_reclass.  I forgot that I don't test PostgreSQL on windows the
 normal way.
 I use the zipped EDB builds and do not launch the instances as a service.
 So the EDB zipped builds may be a little different from the installer ones
 or the fact I launch them from a batch script rather than a service may
 also make a difference.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1432#comment:7>
