[postgis-devel] [PostGIS] #1433: Get rid of SE functions and move remaining sql mm to postgis.sql.in.c
PostGIS trac at osgeo.org
Thu Jan 5 11:43:25 PST 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  task     |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 sqlmm.sql.inc.c is a bit of a misnomer because it has all ESRI ArcSDE
 compatible functions (which we don't think ESRI even uses when PosTGIS is
 snapped into an SDE belt), and has some sql mm, but most sqlmm are already
 in postgis.sql.c except for the linear referencing ones.
 I'm almost done removing SE functions and will merge the rest of functions
 into postgis.sql.in.c when I am done
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1433>
