[postgis-devel] assertive regressions
Sandro Santilli strk at keybit.net
Fri Jan 6 14:36:57 PST 2012
On Fri, Jan 06, 2012 at 02:32:08PM -0800, Chris Hodgson wrote:
> What actually needs to be done on Hudson?
> #1208 says to add --with-raster and --with-topology, but it seems to
> me this is no longer necessary if these are now defaults?
They are not, as far as I can tell.
Maybe they'll become, but they aren't yet.
> #1405 says to pass RUNTESTFLAGS='-v' to make check, which should be
> straightforward enough...
> I guess I also need to get the new geos installed and configure all
> the builds to use it in addition to regressing against the older
> versions...
Right, it'll take GEOS 3.3.2 for --with-topology to be allowed.
> What else, if anything? I'm not sure when I'll be able to get to it...
This seem to be a good reason to think about a more distributed approach.
I'd love to see the osgeo buildbot coming back.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
