[postgis-devel] [PostGIS] #1066: [raster] raster crashes server with arbitrary tests
PostGIS trac at osgeo.org
Sat Jan 7 20:59:15 PST 2012
  Reporter:  robe            |       Owner:  dustymugs
      Type:  defect          |      Status:  assigned
  Priority:  blocker         |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:                  |    Keywords:
Comment(by robe):
 I tested on my prior build (I forget how longer ago -- probably not more
 than a week) on my windows 2008 64-bit box and if I run from pgAdmin III
 -- I get this error:
 ERROR:  out of memory
 DETAIL:  Failed on request of size 536870912.
 So the last bit about encoding might just be some conversion thing psql is
 trying to do and can probably be ignored is my guess.  So its just the out
 of memory and failed on request of size
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1066#comment:18>
