[postgis-devel] [PostGIS] #835: ST_CollectionExtract returns EMPTY or NULL inconsistently
trac at osgeo.org
Mon Jan 9 08:21:56 PST 2012
Reporter: strk | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: new => closed
* resolution: => fixed
Comment:
Ok, I've fixed liblwgeom to return typed EMPTIES in absence of matching
types (r8717)
But liblwgeom only wants COLLECTION input so can't do everything on
itself.
The wrapper I then fixed to always return NULL on type miss, no matter
input
(be it a complex multilevel collection or a simple empty, of any type).
This is r8718.
Note that I had to change an expected return in regress/regress.sql (test
159) -- other existing tests were in tickets.sql and expected NULL for
other kind of inputs.
At least we're consistent now: NULL return when no matches are found.
It's easy for me to get back on typed empty instead, if you scream loud
enough.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/835#comment:3>
