[postgis-devel] [PostGIS] #991: Set remaining bits in type byte to zero
PostGIS trac at osgeo.org
Tue Jan 10 00:41:30 PST 2012
  Reporter:  pramsey      |       Owner:  strk
      Type:  enhancement  |      Status:  closed
  Priority:  high         |   Milestone:  PostGIS 2.0.0
 Component:  postgis      |     Version:  trunk
Resolution:  fixed        |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 It seems to me we're fine here. All code writing type is copying an
 uint32_t value verbatim after checking it to match existing type macros.
 Any unknown value would trigger an error. Known values are up to 15.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/991#comment:2>
