[postgis-devel] [PostGIS] #475: ST_Simple should return false with duplicate points
PostGIS trac at osgeo.org
Tue Jan 10 09:13:40 PST 2012
 Reporter:  kneufeld  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  low       |   Milestone:  PostGIS 2.0.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
Comment(by strk):
 They talk about points, not vertices. Listing the same vertex twice could
 be just seen as a redundancy but doesn't change the point set defined by
 the line.
 What do other spatial database return ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/475#comment:1>
