[postgis-devel] [PostGIS] #1444: Hudson is failing on trunk
PostGIS trac at osgeo.org
Tue Jan 10 12:54:23 PST 2012
 Reporter:  robe        |       Owner:  chodgson
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:  PostGIS 2.0.0
Component:  management  |     Version:  trunk
 Keywords:              |
Comment(by chodgson):
 If you go and look at hudson there are currently two builds failing:
 http://office.refractions.net:1500/
 regress-1.5 is failing (for the past month) because of tickets test #1344
 producing different results due to changes in the hex output format in
 postgres 9.0... not sure how best to address that.
 trunk is failing because of a XML error apparently introduced in r8735.
 The error message you quoted appears at the end of the failed trunk build,
 after a whole bunch of xml errors:
 http://office.refractions.net:1500/job/PostGIS-trunk-
 build/lastFailedBuild/console
 Note that all this information is available from the the Hudson interface,
 with no login required, only a minute or two of poking around.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1444#comment:1>
