[postgis-devel] Extensions
Paragon Corporation lr at pcorp.us
Tue Jan 10 14:35:46 PST 2012
 I tested it generates and installs
postgis--2.0.0SVN.sql
postgis.control
which is right, but doesn't seem to be generating the upgrade scripts.  Is
that what you are getting too?
> -----Original Message-----
> From: Paragon Corporation [mailto:lr at pcorp.us]
> Sent: Tuesday, January 10, 2012 5:10 PM
> To: 'Paul Ramsey'; 'PostGIS Development Discussion'
> Subject: RE: Extensions
> Sure.  I'll test on mine to see what is wrong or if it works
> on mine.  You were testing with 9.1 right?
> postgis_raster_upgrade_minor.sql
> is a combination of postgis_upgrade_minor.sql,
> and some special logic needed for extensions to remove stuff
> e.g. can't have begin commit clauses and if you drop
> something like a type have to remove from extension before
> you can drop it.
> though that doesn't explain why the various versions aren't
> being installed.
> Thanks,
> Regina
> > From: pramsey at cleverelephant.ca
> > [mailto:pramsey at cleverelephant.ca] On Behalf Of Paul Ramsey
> > Sent: Tuesday, January 10, 2012 4:58 PM
> > To: PostGIS Development Discussion
> > Cc: Paragon Corporation
> > Subject: Extensions
> > Regina,
> > I've added the extensions into the autoconf system, but
> there are some
> > subtleties and concerns.
> > First the subtleties...
> > You'll note that
> >   EXTVERSION    = @POSTGIS_LIB_VERSION@
> > is the very obvious way the current version is brought into the
> > scripts.
> > If you look further down, you'll see a target named
> >   sql_minor_upgrade
> > and some fancy bash scripting. That creates all the micro version
> > targets up to the current micro version, and also includes
> smarts so
> > that if the current version is 2.0.0alpha3, it generates
> micro version
> > upgrades from 2.0.0alpha1, and 2.0.0alpha2.
> > Now, looking at that target I got concerned that the only
> input file
> > was postgis_raster_upgrade_minor.sql so I changed it to
> what I thought
> > made sense, postgis_upgrade_minor.sql.
> > However I'm sure that's wrong in a different way.
> > I also note that when I run 'make all', I'm not seeing what
> I expect
> > as a minimum in the ./sql file, namely a postgis--2.0.0.sql
> file, just
> > a bare postgis.sql file. So it seems there's other brings broke?
> > Anyhow, the micro version generator and the version
> substitution work.
> > To get in synch with your extension testing, we can set the
> > Version.config in trunk to 2.0.0alpha1 for now, and then release it
> > shortly once you think the extensions work. Yes?
> > p.
