[postgis-devel] Extensions
Paul Ramsey pramsey at opengeo.org
Tue Jan 10 14:39:15 PST 2012
There are no upgrade scripts for that version number. If you set the
Version.config to 2.0.0a18 you'll see upgrade scripts generated.
On Tue, Jan 10, 2012 at 2:35 PM, Paragon Corporation <lr at pcorp.us> wrote:
>  I tested it generates and installs
> postgis--2.0.0SVN.sql
> postgis.control
> which is right, but doesn't seem to be generating the upgrade scripts.  Is
> that what you are getting too?
>> -----Original Message-----
>> From: Paragon Corporation [mailto:lr at pcorp.us]
>> Sent: Tuesday, January 10, 2012 5:10 PM
>> To: 'Paul Ramsey'; 'PostGIS Development Discussion'
>> Subject: RE: Extensions
>> Sure.  I'll test on mine to see what is wrong or if it works
>> on mine.  You were testing with 9.1 right?
>> postgis_raster_upgrade_minor.sql
>> is a combination of postgis_upgrade_minor.sql,
>> and some special logic needed for extensions to remove stuff
>> e.g. can't have begin commit clauses and if you drop
>> something like a type have to remove from extension before
>> you can drop it.
>> though that doesn't explain why the various versions aren't
>> being installed.
>> Thanks,
>> Regina
>> > From: pramsey at cleverelephant.ca
>> > [mailto:pramsey at cleverelephant.ca] On Behalf Of Paul Ramsey
>> > Sent: Tuesday, January 10, 2012 4:58 PM
>> > To: PostGIS Development Discussion
>> > Cc: Paragon Corporation
>> > Subject: Extensions
>> > Regina,
>> > I've added the extensions into the autoconf system, but
>> there are some
>> > subtleties and concerns.
>> > First the subtleties...
>> > You'll note that
>> >   EXTVERSION    = @POSTGIS_LIB_VERSION@
>> > is the very obvious way the current version is brought into the
>> > scripts.
>> > If you look further down, you'll see a target named
>> >   sql_minor_upgrade
>> > and some fancy bash scripting. That creates all the micro version
>> > targets up to the current micro version, and also includes
>> smarts so
>> > that if the current version is 2.0.0alpha3, it generates
>> micro version
>> > upgrades from 2.0.0alpha1, and 2.0.0alpha2.
>> > Now, looking at that target I got concerned that the only
>> input file
>> > was postgis_raster_upgrade_minor.sql so I changed it to
>> what I thought
>> > made sense, postgis_upgrade_minor.sql.
>> > However I'm sure that's wrong in a different way.
>> > I also note that when I run 'make all', I'm not seeing what
>> I expect
>> > as a minimum in the ./sql file, namely a postgis--2.0.0.sql
>> file, just
>> > a bare postgis.sql file. So it seems there's other brings broke?
>> > Anyhow, the micro version generator and the version
>> substitution work.
>> > To get in synch with your extension testing, we can set the
>> > Version.config in trunk to 2.0.0alpha1 for now, and then release it
>> > shortly once you think the extensions work. Yes?
>> > p.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
