[postgis-devel] [PostGIS] #1444: Hudson is failing on trunk
PostGIS trac at osgeo.org
Tue Jan 10 23:52:49 PST 2012
 Reporter:  robe        |       Owner:  chodgson
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:  PostGIS 2.0.0
Component:  management  |     Version:  trunk
 Keywords:              |
Comment(by robe):
 I've always seen them on Hudson and strk has complained about those, but
 Hudson has never had a problem with it and has succeeded even with them.
 so I don't think that is the core of the problem why it is registering a
 failure.
 To be honest I am not setup to build the pdf so don't know.
 If you look at:
 http://office.refractions.net:1500/job/PostGIS-trunk-build/3609/console
 Which was a successful build, it has those notices too.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1444#comment:6>
