[postgis-devel] Documentation and comments in tarball
Sandro Santilli
strk at keybit.net
Wed Jan 11 00:51:55 PST 2012
On Tue, Jan 10, 2012 at 08:30:38PM -0500, Greg Troxel wrote:
> So I modified (locally) pkgsrc/database/postgresql-postgis to build the
> documents, to find out what it took. It turns out I had to add only
> libxslt (2.5 MB), docbook-xsl (13 MB), and ImageMagick (37 MB), which
> aren't all that huge (relatively, because one already needs postgresql
> itself, at 33MB for 8.4).
> I'm guessing most people who build postgis from the tarball don't really
> want to regenerate the docs, so I lean to including them, because the
> build tools are somewhat large compared to what would have been needed
> anyway.
Note that building docs is not mandatory, they aren't built by default.
If all you need is _reading_ the manual you have convenient separate
downloads here: http://www.postgis.org/documentation/
>From a packaging point of view I think docs should be in a separate
package as well (postgis-doc).
> When I tried to build the documents (from the 1.5.3 tarball), I had the
> following problems. I have patches for the first three - should I send
> them here, or file trac tickets and attach, or ?
Note that the documentation discussion is about 2.0, not 1.5.
Anyway, let's see each issue in turn.
> - doc/Makefile.in uses bare 'make' for submakes, it should be $(MAKE)
> so it uses the right command for where GNU make happens to be (gmake
> on BSD, because make is BSD make)
Fixed for 1.5 branch with r8761, 2.0 with r8763.
> - generator fails to clear the malloced 'filename' variable, and copies
> one too few bytes of "../images/", not getting the trailing null,
> resulting in garbage filenames. (Does malloc on Linux clear the
> returned bytes (posix says the contents are unspecified)? I don't
> see how this could have worked.)
Known bug: http://trac.osgeo.org/postgis/ticket/1146
Fixed in 2.0 around 3 weeks ago, now also backported in 1.5 (with r8764).
> - doc/Makefile.in installs to $(PGSQL_MANDIR) etc. without prefixing
> $(DESTDIR), so a DESTDIR install (as used by pkgsrc to create
> packages unprived before installation) fails. (The rest of postgis
> correctly uses DESTDIR.)
Also fixed in 2.0 (ticket #1184). Now backported (r8765).
> - the docs install step uses cp instead of $(INSTALL_DATA) (as
> postgis/Makefile.pgxs does) (minor)
Please file a ticket for this, with a patch if possible.
> - gmake install in docs/ doesn't install the images, and doesn't
> install style.css, but the generated html seems to refer to it. How
> is this supposed to get installed?
Another ticket for this (but I wouldn't target 1.5).
> - there seems not to be a single top-level build/install target to
> invoke if one wants code/doc/comments all at once.
This is by design, as the documentation aren't build by default.
> (Currently, the published pkgsrc entry doesn't try to build documents,
> and has a hand-constructed makefile target to copy the built docs to
> DESTDIR.)
> I can also report that (with geos 3.3.2 and postgresql 8.4), postgis
> 1.5.3 on NetBSD/i386 5_STABLE passes 'gmake check' 100% (as does geos).
Great to hear that, thanks for testing !
--strk;
() Free GIS & Flash consultant/developer
/\ http://strk.keybit.net/services.html
