[postgis-devel] Extensions
Paragon Corporation lr at pcorp.us
Wed Jan 11 00:59:42 PST 2012
Paul,
Great that generates the files correctly now.  Only issue left is that the
upgrade scripts aren't being installed.
I'm just getting the main script 2.0.0a18.sql and control  being installed.
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Paul Ramsey
> Sent: Tuesday, January 10, 2012 9:28 PM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] Extensions
> Perhaps the bash syntax was too new... I've tried another variant.
> P.
> On Tue, Jan 10, 2012 at 4:18 PM, Paragon Corporation
> <lr at pcorp.us> wrote:
> >>  There are no upgrade scripts for that version number. If
> you set the
> > Version.config to 2.0.0a18 you'll see upgrade scripts generated.
> > I changed the version config to 2.0.0a18, but it doesn't install an
> > upgrade script.
> > However I do see in the sql folder that it generates this file:
> > postgis--2.0.0a{17..1}--2.0.0a18.sql
> > Is that a special extension file format I'm not familiar
> with to worf
> > for a1-a17?
> > Thanks,
> > Regina
> > postgis-devel mailing list
> > postgis-devel at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
