[postgis-devel] [PostGIS] #1418: Fix up errors in new loader GUI and add dumper support
PostGIS trac at osgeo.org
Wed Jan 11 01:12:23 PST 2012
 Reporter:  mcayland       |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  blocker        |   Milestone:  PostGIS 2.0.0
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
Comment(by robe):
 Mark,
 I tried the new one and its better.  I like the new log info and the fact
 that window is larger and there seems to be more information than I recall
 getting with the old one which is good.
 Now I can widen the file field.  However I can't widen any other column.
 I still have the annoying issue that the information I overwrite is
 sometimes not taken unless I click on the row.  I had this issue before
 with the old one so it's not a new thing and its kind of intermittent.
 The more annoying issue I see is that the append/create/.. drop down seems
 to be overlaid on top of the table name column so I click in there to
 change the value and sometimes I can guess where the drop down is and
 sometimes I can't.  IT's like some maze backdoor.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1418#comment:8>
