[postgis-devel] [PostGIS] #288: ST_AsBinary should return SQL/MM WKB
PostGIS trac at osgeo.org
Wed Jan 11 06:31:38 PST 2012
  Reporter:  pramsey  |       Owner:  strk
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:  sqlmm, history
Changes (by strk):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 I've found out that ST_AsBinary(geography) is not even using the same code
 path at the postgis level, so it's still old style.
 May I suggest we cast to geometry and do everything there instead ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/288#comment:6>
