[postgis-devel] [PostGIS] #1458: unstable results from st_orderingequals (again!)
trac at osgeo.org
Wed Jan 11 23:42:58 PST 2012
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
strk=# \a \t
Output format is unaligned.
Showing only tuples.
strk=# select st_orderingequals('POINT EMPTY', 'POINT EMPTY');
f
t
In case you don't see it: first call returns FALSE, second call returns
TRUE. Calls are perfectly identical.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1458>
