[postgis-devel] [PostGIS] #1383: Topology: ST_AddEdgeNewFaces() fail to add an edge
PostGIS trac at osgeo.org
Thu Jan 12 08:10:13 PST 2012
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
Comment(by strk):
 More specifically:
 strk=# select ST_DWithin('LINESTRING(-0.2 0.4,-1e-08 0.4)',
                                        'POINT(-1e-08 0.4)',
                                                           0);
  st_dwithin
  f
 (1 row)
 Or, in other words:
 => select ST_DWithin(g, st_endpoint(g), 0) from ( select 'LINESTRING(-0.2
 0.4,-1e-08 0.4)'::geometry as g ) f;
  st_dwithin
  f
 (1 row)
 A segment endpoint is not within 0 distance from the segment.
 Note that the test returns TRUE for the firstpoint...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1383#comment:9>
