[postgis-devel] [PostGIS] #1461: Tiger Geocoder doesn't anticipate irregular spacing in road name
PostGIS trac at osgeo.org
Thu Jan 12 19:39:14 PST 2012
 Reporter:  arencambre      |       Owner:  robe
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  tiger geocoder  |     Version:  trunk
 Keywords:                  |
 The tx_edges table uses '''I- 635''' instead of the more consistent
 '''I-635'''.
 This looks weird but works:
 SELECT ST_AsEWKT(geomout) FROM geocode_intersection('N. Belt Line', 'I-
 635', 'TX', 'Coppell') ORDER BY rating ASC LIMIT 1;
 This looks correct but doesn't work:
 'I-635', 'TX', 'Coppell') ORDER BY rating ASC LIMIT 1;
 Seems like the geocoder needs to work around these kind of errors in the
 Tiger data.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1461>
