[postgis-devel] [PostGIS] #1462: Have TopoGeometry::Geometry always return a MULTI*
PostGIS trac at osgeo.org
Fri Jan 13 01:44:41 PST 2012
 Reporter:  strk      |       Owner:  strk
     Type:  task      |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 Since TopoGeometry types don't make a distinction between a single and a
 multi type (they are: puntual, lineal, areal) it would be more consistent
 to always return a Multi rather than relying on the actual definition.
 The GeometryType(TopoGeometry) override already assumes they are all
 Multi*, so changing the actual cast would be a uniform step in that
 direction.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1462>
