[postgis-devel] Documentation and comments in tarball
Greg Troxel
gdt at ir.bbn.com
Fri Jan 13 08:39:25 PST 2012
"Paragon Corporation" <lr at pcorp.us> writes:
> Greg,
>> On
>> loader/Latin1 ... failed ( wkb test: running shp2pgsql
>> output: /tmp/pgis_reg_17179/loader.err)
>> I get:
>> psql:/tmp/pgis_reg_9886/loader.out:7: ERROR: value too long
>> for type character varying(32)
>> and sure enough the insert statement seems to have more than
>> 32 characters.
>> Is this known, or should I file a ticket?
>> (I can easily test with 8.3, 8.4, 9.0, and 9.1, but as 8.4 is
>> the current pkgsrc default I am trying that first.)
> Interesting. FWIW I get that too but since I was the only one complaining I
> thought was an isolated
> MingW issue. The fix I have is to remark out the nls_build line in
> loader/Makefile.in
> #nls_build = @USE_NLS@
> Curious if that works for you. No one has fixed the issue because well
> "It's only you Regina that is affected :)"
Doing that in Makefile, rerunning config.status, gmake clean, gmake,
gmake check and I still get the test failure.
So, I'll file a ticket as strk suggested.
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120113/1b3909a0/attachment.sig>
