[postgis-devel] broken build - rev8811?
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Sat Jan 14 02:45:45 PST 2012
On 14/01/12 07:21, maplabs at light42.com wrote:
> gcc -g -O2  -fPIC -DPIC  -Wall -Wmissing-prototypes    -I. -I. -I/usr/include/postgresql/9.1/server -I/usr/include/postgresql/internal -D_GNU_SOURCE -I/usr/include/libxml2  -I/usr/include/tcl8.5  -c -o shp2pgsql-cli.o
> shp2pgsql-cli.cshp2pgsql-cli.c: In function ‘main’:shp2pgsql-cli.c:75:27: error: ‘PGSQL_LOCALEDIR’ undeclared (first use in this function)
> shp2pgsql-cli.c:75:27: note: each undeclared identifier is reported only once for each function it appears in
> make[1]: *** [shp2pgsql-cli.o] Error 1
> make[1]: Leaving directory `/home/shared/srcs_wheezy/postgis_trunk/loader'
> make: *** [all] Error 1
> dbb at wheezyvm:/home/shared/srcs_wheezy/postgis_trunk$ svn up
> At revision 8811.
Hi Brian,
That's probably caused by the changes I committed yesterday which
updated configure.ac. You'll need to re-run autogen.sh and configure
before running make once again.
HTH,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
