[postgis-devel] perl dependency, via postgresql, perhaps better direct?
Greg Troxel gdt at ir.bbn.com
Sat Jan 14 06:27:56 PST 2012
I'm building svn trunk against various postgresql versions, and find
that with 9.0 and 9.1, the build fails because in my postgresql builds
pgxs.mk has PERL set to 'missing'.  (While I have perl installed, it's
hidden from the package build on purpose as part of a plan to avoid
unexpressed dependencies, and there's a split package
postgresql91-plperl for those who want perl stored procedures.)
postgis has a perl script utils/postgis_proc_upgrade.pl used in the
build.  It seems like it would be better to find perl with autoconf as
part of the postgis build, because postgis simply needs perl as a build
tool, and doesn't actually depend on any postgresql perl support.
Basically, this would be one line in configure.ac and using @PERL@
instead of $(PERL).
Greg
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120114/4e5e3c19/attachment.sig>
