[postgis-devel] Should EMPTY be spatially equal to self ?
Paragon Corporation lr at pcorp.us
Sun Jan 15 13:32:15 PST 2012
> I don't expect anyone to do anything.
> Anyway, if they do, they'll get a clean version of the 2.0 release.
> And note that it's still too early to do that, as 2.0 isn't out yet.
> Also note that the only change you get by doing or not the
> dump/reload is using or not an index when you use the ~= operator.
Okay don't care much about that operator as long as you don't change
ST_Equals to
use it.  That operator is not used much anyway and is only in
ST_OrderingEquals which is
also not that commonly used.
> Also note that the documentation (the one you removed) was
> already advertising ~= as using an index.
I don't plan to put it back.  That operator has aggrevated me since 1.3-1.4
because whenever I deal with someone -- I have no way of knowing what that
operator will do.
And now strk is using my own documentation against me :)
If we bring it back it should go by another name.
> Which "same version" ? 2.0.0SVN ?
> You can't expect an "SVN" version to ever be equal to self..
I'm not talking about that.  I'm talking about tools that have to support
1.3, 1.4, 1.5, 2.0.0 (if you use 1.3 it means goemetric quality, if you use
1.4-1.5 it means
geometric equality or bounding box equality, if you use 2.0.0 it may or may
not use an index (and right now since we
don't have any tagged releases -- we can't even tell people how they need to
upgrade).
You get my frustration?
> > You know what would be REALLY USEFUL.  IF we had a real geometric
> > equality operator like ~= used to be in 1.3 so that people
> who want to
> > use CONSTRAINT EXCLUSION to enforce uniqueness of their geometries
> > CAN.
> Filed a ticket about it ?
I meant to say EXCLUSION constraints -- and yes ticketed at:
http://trac.osgeo.org/postgis/ticket/1471
Note we probably could easily squeeze this in 2.0, but I don't care cause I
have no need for it at the moment, but I know several on the list
have expressed interest mostly for point data which ~= doesn't quite work
for because of the float / double issue you can get points really close that
are not the same that would be flagged wrong.
Thanks,
Regina
