[postgis-devel] making docs uses the net, html not build with gmake docs
Chris Hodgson chodgson at refractions.net
Mon Jan 16 09:47:14 PST 2012
On 12-01-16 07:28 AM, Mark Cave-Ayland wrote:
> On 16/01/12 14:22, Sandro Santilli wrote:
>>> Does this happen for other people, or is it that my xsltproc is missing
>>> something it should have, or something else?
>> It happens for me as well. It even fetches stylesheets that I do have
>> locally.
>> Would be important to have this fixed. Worth a ticket.
> Hmmm if they are installed locally it shouldn't need to do that - at
> least on my Debian Squeeze system, installing the various stylesheet
> packages made it go away. I will freely confess that I haven't
> attempted to build the documentation for a while though so things may
> have changed.
> Are we deliberately asking for a specific version of a stylesheet that
> some people aren't likely to have?
I believe it should be really straightforward on distros packaged in the
last 5 or 6 years. I had a little trouble with the RHEL 5 based system
that has the hudson buildbot on it, but in the worst case you can
download the raw docbook and mathml zip files from the unpackage
virtually anywhere (usr/share/xml looked good) structure and play with
the xmlcatalog tool to add the appropriate links into your xml catalog
files(/etc/xml/catalog on my distro).
See here: http://trac.osgeo.org/postgis/ticket/963
HTH,
Chris
