[postgis-devel] [PostGIS] #852: The use of tolerance in function point_in_ring is not robust.
PostGIS trac at osgeo.org
Wed Jan 18 08:03:37 PST 2012
 Reporter:  nicklas  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Comment(by strk):
 Ok, I checked, it is PostGIS implementation, not GEOS's.
 GEOS correctly returns FALSE for both cases. The point is slightly above
 the polygon.
 Any reason not to disable the short-circuit ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/852#comment:3>
