[postgis-devel] PostGIS 2.0 SRID constraint
Paul Ramsey pramsey at opengeo.org
Thu Jan 19 14:43:36 PST 2012
Er, add a couple 100K instead of 9M.
On Thu, Jan 19, 2012 at 2:42 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> I think we can just at the spatialreference.org folks to only add 1M
> to the ESRI code instead of adding 9M. The ESRI code itself is only in
> the 100K range.
> P
> On Thu, Jan 19, 2012 at 2:39 PM, dustymugs <dustymugs at gmail.com> wrote:
>>>> I just hit this uploading some parcel data that uses an ESRI projection.
>>> Example url ?
>> For ESRI:102645, click on the PostGIS INSERT statement...
>> http://spatialreference.org/ref/esri/102645/
>> -bborie
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
