[postgis-devel] [PostGIS] #1485: Can't make check under mingw anymore
PostGIS trac at osgeo.org
Thu Jan 19 23:49:26 PST 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by strk):
 Did you try with alpha1 ? I think I fixed it at r8878
 You'll need ./configure again after update
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1485#comment:3>
