[postgis-devel] Bogus CH entry in spatial_ref_sys
Sandro Santilli strk at keybit.net
Mon Jan 23 08:14:43 PST 2012
proj4text entries for EPSG:1449 and EPSG:1450 are equal in spatial_ref_sys.sql:
  --- EPSG 4149 : CH1903
  INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (4149,'EPSG',4149,'GEOGCS["CH1903",DATUM["CH1903",SPHEROID["Bessel 1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],TOWGS84[674.374,15.056,405.346,0,0,0,0],AUTHORITY["EPSG","6149"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4149"]]','+proj=longlat +ellps=bessel +towgs84=674.374,15.056,405.346,0,0,0,0 +no_defs ');
  --- EPSG 4150 : CH1903+
  INSERT INTO "spatial_ref_sys" ("srid","auth_name","auth_srid","srtext","proj4text") VALUES (4150,'EPSG',4150,'GEOGCS["CH1903+",DATUM["CH1903",SPHEROID["Bessel 1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],TOWGS84[674.374,15.056,405.346,0,0,0,0],AUTHORITY["EPSG","6150"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4150"]]','+proj=longlat +ellps=bessel +towgs84=674.374,15.056,405.346,0,0,0,0 +no_defs ');
while they are different in proj4/nad/epsg:
  # CH1903
  <4149> +proj=longlat +ellps=bessel +towgs84=674.4,15.1,405.3,0,0,0,0 +no_defs  <>
  # CH1903+
  <4150> +proj=longlat +ellps=bessel +towgs84=674.374,15.056,405.346,0,0,0,0 +no_defs  <>
Basically the code or CH1903 (EPSG:4149) seems bogus.
spatial_ref_sys is from postgis trunk.
nad/epsg is from proj4 trunk.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
