[postgis-devel] [PostGIS] #1493: wrong proj4text in spatial_ref_sys for SRID 4149
PostGIS trac at osgeo.org
Mon Jan 23 09:28:45 PST 2012
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 From: http://postgis.refractions.net/pipermail/postgis-
 devel/2012-January/017805.html
 proj4text entries for EPSG:1449 and EPSG:1450 are equal in
 spatial_ref_sys.sql:
   --- EPSG 4149 : CH1903
   INSERT INTO "spatial_ref_sys"
 ("srid","auth_name","auth_srid","srtext","proj4text") VALUES
 (4149,'EPSG',4149,'GEOGCS["CH1903",DATUM["CH1903",SPHEROID["Bessel
 1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],TOWGS84[674.374,15.056,405.346,0,0,0,0],AUTHORITY["EPSG","6149"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4149"]]','+proj=longlat
 +ellps=bessel +towgs84=674.374,15.056,405.346,0,0,0,0 +no_defs ');
   --- EPSG 4150 : CH1903+
 (4150,'EPSG',4150,'GEOGCS["CH1903+",DATUM["CH1903",SPHEROID["Bessel
 1841",6377397.155,299.1528128,AUTHORITY["EPSG","7004"]],TOWGS84[674.374,15.056,405.346,0,0,0,0],AUTHORITY["EPSG","6150"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4150"]]','+proj=longlat
 while they are different in proj4/nad/epsg:
   # CH1903
   <4149> +proj=longlat +ellps=bessel +towgs84=674.4,15.1,405.3,0,0,0,0
 +no_defs  <>
   # CH1903+
   <4150> +proj=longlat +ellps=bessel
 +towgs84=674.374,15.056,405.346,0,0,0,0 +no_defs  <>
 Basically the code or CH1903 (EPSG:4149) seems bogus.
 spatial_ref_sys is from postgis trunk.
 nad/epsg is from proj4 trunk.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1493>
