[postgis-devel] Build failed in Hudson: PostGIS-trunk-build #3760
dustymugs dustymugs at gmail.com
Mon Jan 23 13:08:37 PST 2012
1.9.0 would be ideal.
-bborie
On 01/23/2012 01:08 PM, Chris Hodgson wrote:
> What version of gdal should I install on the buildbot?
> Chris
> On 12-01-20 03:42 PM, Paul Ramsey wrote:
>> Chris,
>> Could you set the buildbot to use --without-raster in its configure,
>> or add gdal to it please?
>> Thanks,
>> P.
>> On Fri, Jan 20, 2012 at 3:06 PM,<chodgson at refractions.net> wrote:
>>> See<http://office.refractions.net:1500/job/PostGIS-trunk-build/3760/changes>
>>> Changes:
>>> [Paul Ramsey] Make raster on by default and --without-raster the
>>> configuration parameter to disable it.
>>> Started by remote host 140.211.15.71
>>> Updating http://svn.osgeo.org/postgis/trunk
>>> U configure.ac
>>> At revision 8896
>>> [workspace] $ /bin/sh -xe /tmp/hudson671320016005153531.sh
>>> ++ svn info src
>>> ++ grep 'Last Changed Rev:'
>>> ++ cut -f4 '-d '
>>> + SVN_REVISION=8896
>>> + rm -rf build
>>> + rm -rf rel
>>> + rm -rf postgis-2.0.0SVN postgis-2.0.0SVN.tar.gz
>>> + svn export src rel
>>> Export complete.
>>> + cd ./rel
>>> + ./autogen.sh
>>> * Running /usr/bin/libtoolize (1.5.22)
>>> OPTIONS = --force --copy
>>> You should add the contents of `/usr/share/aclocal/libtool.m4' to
>>> `aclocal.m4'.
>>> * Running /usr/bin/aclocal (1.9.6)
>>> * Running /usr/bin/autoconf (2.59)
>>> Now you are ready to run './configure'
>>> + rm -rf autom4te.cache
>>> + rm -rf HOWTO_RELEASE
>>> + rm -rf make_dist.sh
>>> + echo SVN_REVISION=8896
>>> + cd<http://office.refractions.net:1500/job/PostGIS-trunk-build/ws/>
>>> + svn export src build
>>> Export complete.
>>> + cd build
>>> + ./autogen.sh
>>> `aclocal.m4'.
>>> + ./configure
>>> --with-pgconfig=/var/home/buildbot/opt/pgsql/9.0.1/bin/pg_config
>>> --with-geosconfig=/var/home/buildbot/opt/geos/3.2.2/bin/geos-config
>>> --with-projdir=/var/home/buildbot/opt/proj/4.7.0
>>> checking build system type... i686-redhat-linux-gnu
>>> checking host system type... i686-redhat-linux-gnu
>>> checking for gcc... gcc
>>> checking for C compiler default output file name... a.out
>>> checking whether the C compiler works... yes
>>> checking whether we are cross compiling... no
>>> checking for suffix of executables...
>>> checking for suffix of object files... o
>>> checking whether we are using the GNU C compiler... yes
>>> checking whether gcc accepts -g... yes
>>> checking for gcc option to accept ANSI C... none needed
>>> checking for a sed that does not truncate output... /bin/sed
>>> checking for egrep... grep -E
>>> checking for ld used by gcc... /usr/bin/ld
>>> checking if the linker (/usr/bin/ld) is GNU ld... yes
>>> checking for /usr/bin/ld option to reload object files... -r
>>> checking for BSD-compatible nm... /usr/bin/nm -B
>>> checking whether ln -s works... yes
>>> checking how to recognise dependent libraries... pass_all
>>> checking how to run the C preprocessor... gcc -E
>>> checking for ANSI C header files... yes
>>> checking for sys/types.h... yes
>>> checking for sys/stat.h... yes
>>> checking for stdlib.h... yes
>>> checking for string.h... yes
>>> checking for memory.h... yes
>>> checking for strings.h... yes
>>> checking for inttypes.h... yes
>>> checking for stdint.h... yes
>>> checking for unistd.h... yes
>>> checking dlfcn.h usability... yes
>>> checking dlfcn.h presence... yes
>>> checking for dlfcn.h... yes
>>> checking for g++... g++
>>> checking whether we are using the GNU C++ compiler... yes
>>> checking whether g++ accepts -g... yes
>>> checking how to run the C++ preprocessor... g++ -E
>>> checking for g77... no
>>> checking for f77... no
>>> checking for xlf... no
>>> checking for frt... no
>>> checking for pgf77... no
>>> checking for fort77... no
>>> checking for fl32... no
>>> checking for af77... no
>>> checking for f90... no
>>> checking for xlf90... no
>>> checking for pgf90... no
>>> checking for epcf90... no
>>> checking for f95... no
>>> checking for fort... no
>>> checking for xlf95... no
>>> checking for ifc... no
>>> checking for efc... no
>>> checking for pgf95... no
>>> checking for lf95... no
>>> checking for gfortran... no
>>> checking whether we are using the GNU Fortran 77 compiler... no
>>> checking whether accepts -g... no
>>> checking the maximum length of command line arguments... 32768
>>> checking command to parse /usr/bin/nm -B output from gcc object... ok
>>> checking for objdir... .libs
>>> checking for ar... ar
>>> checking for ranlib... ranlib
>>> checking for strip... strip
>>> checking if gcc supports -fno-rtti -fno-exceptions... no
>>> checking for gcc option to produce PIC... -fPIC
>>> checking if gcc PIC flag -fPIC works... yes
>>> checking if gcc static flag -static works... yes
>>> checking if gcc supports -c -o file.o... yes
>>> checking whether the gcc linker (/usr/bin/ld) supports shared
>>> libraries... yes
>>> checking whether -lc should be explicitly linked in... no
>>> checking dynamic linker characteristics... GNU/Linux ld.so
>>> checking how to hardcode library paths into programs... immediate
>>> checking whether stripping libraries is possible... yes
>>> checking if libtool supports shared libraries... yes
>>> checking whether to build shared libraries... yes
>>> checking whether to build static libraries... yes
>>> configure: creating libtool
>>> appending configuration tag "CXX" to libtool
>>> checking for ld used by g++... /usr/bin/ld
>>> checking whether the g++ linker (/usr/bin/ld) supports shared
>>> libraries... yes
>>> checking for g++ option to produce PIC... -fPIC
>>> checking if g++ PIC flag -fPIC works... yes
>>> checking if g++ static flag -static works... yes
>>> checking if g++ supports -c -o file.o... yes
>>> libraries... yes
>>> appending configuration tag "F77" to libtool
>>> checking for gcc... (cached) gcc
>>> checking whether we are using the GNU C compiler... (cached) yes
>>> checking whether gcc accepts -g... (cached) yes
>>> checking for gcc option to accept ANSI C... (cached) none needed
>>> checking whether we are using the GNU C++ compiler... (cached) yes
>>> checking whether g++ accepts -g... (cached) yes
>>> checking if g++ supports -Wall... yes
>>> checking if g++ supports -Wmissing-prototypes... yes
>>> checking if g++ supports -ffloat-store... yes
>>> checking for flex... flex
>>> checking for yywrap in -lfl... yes
>>> checking lex output file root... lex.yy
>>> checking whether yytext is a pointer... yes
>>> checking for bison... bison -y
>>> checking ieeefp.h usability... no
>>> checking ieeefp.h presence... no
>>> checking for ieeefp.h... no
>>> checking for vasprintf... yes
>>> checking for asprintf... yes
>>> checking for perl... /usr/bin/perl
>>> checking for convert... /usr/bin/convert
>>> checking for xsltproc... /usr/bin/xsltproc
>>> checking for dblatex... /usr/bin/dblatex
>>> checking CUnit/CUnit.h usability... yes
>>> checking CUnit/CUnit.h presence... yes
>>> checking for CUnit/CUnit.h... yes
>>> checking for CU_initialize_registry in -lcunit... yes
>>> checking iconv.h usability... yes
>>> checking iconv.h presence... yes
>>> checking for iconv.h... yes
>>> checking for libiconv_open in -liconv... no
>>> checking for iconv_open in -lc... yes
>>> checking for iconvctl... no
>>> checking for libiconvctl... no
>>> Using user-specified pg_config file:
>>> checking PostgreSQL version... PostgreSQL 9.0.1
>>> checking libpq-fe.h usability... yes
>>> checking libpq-fe.h presence... yes
>>> checking for libpq-fe.h... yes
>>> checking for PQserverVersion in -lpq... yes
>>> checking for xml2-config... /usr/bin/xml2-config
>>> checking libxml/tree.h usability... yes
>>> checking libxml/tree.h presence... yes
>>> checking for libxml/tree.h... yes
>>> checking libxml/parser.h usability... yes
>>> checking libxml/parser.h presence... yes
>>> checking for libxml/parser.h... yes
>>> checking libxml/xpath.h usability... yes
>>> checking libxml/xpath.h presence... yes
>>> checking for libxml/xpath.h... yes
>>> checking libxml/xpathInternals.h usability... yes
>>> checking libxml/xpathInternals.h presence... yes
>>> checking for libxml/xpathInternals.h... yes
>>> checking for xmlInitParser in -lxml2... yes
>>> Using user-specified geos-config file:
>>> checking GEOS version... 3.2.2
>>> checking geos_c.h usability... yes
>>> checking geos_c.h presence... yes
>>> checking for geos_c.h... yes
>>> checking for initGEOS in -lgeos_c... yes
>>> checking whether make sets $(MAKE)... yes
>>> checking for a BSD-compatible install... /usr/bin/install -c
>>> checking whether NLS is requested... yes
>>> checking for msgfmt... /usr/bin/msgfmt
>>> checking for gmsgfmt... /usr/bin/msgfmt
>>> checking for xgettext... /usr/bin/xgettext
>>> checking for msgmerge... /usr/bin/msgmerge
>>> checking for ld used by GCC... /usr/bin/ld
>>> checking for shared library run path origin... done
>>> checking for CFPreferencesCopyAppValue... no
>>> checking for CFLocaleCopyCurrent... no
>>> checking for GNU gettext in libc... yes
>>> checking whether to use NLS... yes
>>> checking where the gettext function comes from... libc
>>> Using user-specified proj directory: /var/home/buildbot/opt/proj/4.7.0
>>> checking proj_api.h usability... yes
>>> checking proj_api.h presence... yes
>>> checking for proj_api.h... yes
>>> checking for pj_get_release in -lproj... yes
>>> checking json/json.h usability... no
>>> checking json/json.h presence... no
>>> checking for json/json.h... no
>>> checking for json_object_get in -ljson... no
>>> Could not open input file sqlmm.sql.in.c
>>> checking for GDAL>= 1.6.0... which: no gdal-config in
>>> (/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/var/home/buildbot/bin)
>>> not found
>>> configure: error: gdal-config not found. With --without-raster or try
>>> --with-gdalconfig=<path to gdal-config>
>>> Archiving artifacts
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
