[postgis-devel] [PostGIS] #1485: Can't make check under mingw anymore
PostGIS trac at osgeo.org
Tue Jan 24 03:47:15 PST 2012
 Reporter:  robe                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  blocker                |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by robe):
 the main difference aside from my mongw use is I test against my vc++
 PostgreSQL not the mingw compiled one with env variables like this
 export PG_VER=91
 export PATHOLD=PATH
 export
 PATH="/c/projects/pg/pg${PG_VER}/bin/:/c/projects/gdal/rel-${GDAL_VER}/bin/:$PATHOLD"
 export PGPORT=5441
 export PG_WINVER=9.1
 export PGUSER=postgres
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1485#comment:5>
