[postgis-devel] [PostGIS] #1499: topology regression tests fail creating already-present schema
PostGIS trac at osgeo.org
Wed Jan 25 16:11:29 PST 2012
 Reporter:  gdt       |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 With r8916, pgsql 9.1.2 on NetBSD/i386 5ish, the topology tests pass on
 the first pass, and then fail to upgrade:
 Upgrading topology
  Something went wrong during db initialization (topology upgrade).
  For details, check /tmp/pgis_reg_1268/regress_log
 gmake[1]: *** [check] Error 1
 In the log:
 psql:/home/gdt/SOFTWARE/POSTGIS/postgis/regress/00-regress-
 install/share/contrib/postgis/topology_upgrade_20_minor.sql:212: ERROR:
 schema "topology" already exists
 I tried commenting out the drop schema statement, but that caused it
 to happen during installation, which also failed.  So it seems upgrade
 needs to cope with the schema already being present.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1499>
