[postgis-devel] [PostGIS] #1503: ST_AddIsoNode doesn't check face containment if 0 is given
PostGIS trac at osgeo.org
Fri Jan 27 01:53:25 PST 2012
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 When pasing a non-null value as containing_face to ST_addIsoNode the
 function checks if the node is _really_ inside the mentioned face.
 When passing a null, the function figures out by itself.
 When passing 0, no check is performed !
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1503>
