[postgis-devel] [PostGIS] #982: ST_ChangeEdgeGeom doesn't let you change geometry of a closed edge
PostGIS trac at osgeo.org
Mon Jan 30 06:40:44 PST 2012
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  high      |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 It is even worst than I thought in that updating face linking and edge
 linking may also be needed for non-closed edges, when the new edge ends up
 in a different face. Funny enough, the SQL/MM specification do not
 consider that case at all !
Ticket URL: <http://trac.osgeo.org/postgis/ticket/982#comment:3>
