[postgis-devel] [PostGIS] #1292: ST_SnapToGrid returns a value out of range
PostGIS trac at osgeo.org
Mon Jan 30 13:35:28 PST 2012
 Reporter:  realityexists  |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  postgis        |     Version:  trunk
 Keywords:                 |
Comment(by pramsey):
 OK, so this is tricky. Ignore the text for the moment. SnapToGrid builds a
 virtual grid out from the origin and then snaps your coordinates to it.
 The net result is things move, for example
 {{{postgis20=# SELECT
 sT_astext(ST_SnapToGrid(ST_Transform(ST_GeomFromText('POINT(179.8 50)',
 4269), 4326), 0.00007)::geography);
          st_astext
  POINT(179.79997 50.00002)
 Now, when you print out doubles, you only see a small portion of their
 total precision. The fact is that snapping even to 0.00001 is perturbing
 the coordinates slightly. And sometimes slightly positively. Now you might
 say "0.00001 fits evening into 180" and you'd be right, but that's in base
 10, and the computer is working in base 2. So the grid formed by 0.00001
 might actually snap 180 to something slightly larger than 180. This is
 legal and correct.
 The question is what to do about it. One possibility would be to provide a
 function to wrap the coordinates to the geodetic bounds. This would have
 the effect of translating your perturbed points from 180plusabit to
 -180plusabit. But once you got into geographics it would all be the same,
 effectively.
 I don't think we want the cast to do the wrap automatically (at least,
 people have told me that would be bad). Although I'm increasingly unsure
 of that.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1292#comment:3>
