[postgis-devel] [PostGIS] #1024: Change 3D relationship functions to use &&& instead of &&
PostGIS trac at osgeo.org
Mon Jan 30 14:25:18 PST 2012
 Reporter:  robe     |       Owner:  pramsey
     Type:  task     |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by nicklas):
 As seen in the attached .sql the planner didn't react as I had hoped.
 It looks at the &&& operator and judge it as more expensive than &&
 operator.
 Is there a "cost" somewhere? I didn't see it.
 In the example in the file with 100000 records the planner chooses a heap
 bit scan if it is forced to use &&& operator. If it can chose it uses an
 index scan on the && operator and ignores the &&& operator.
 Interesting is that if I increase the number of records to 1000000, then
 it uses a hep bit scan also with && operator but still chooses && over &&&
 operator.
 I really hope there is a cost somewhere to tweak. Or is it just doing
 those decisions from statistics?
 /Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1024#comment:7>
