[postgis-devel] New node splitting algorithm for GiST
Alexander Korotkov aekorotkov at gmail.com
Sun Jul 1 08:00:11 PDT 2012
Done: http://trac.osgeo.org/postgis/ticket/1895
With best regards,
Alexander Korotkov.
On Sun, Jul 1, 2012 at 5:54 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Alex,
> Can you attach this to a ticket.  That way Paul won't forget or one of us
> can remind him when he does :)
> Slate it for 2.1.0
> Thanks,
> Regina
> *From:* postgis-devel-bounces at postgis.refractions.net [mailto:
> postgis-devel-bounces at postgis.refractions.net] *On Behalf Of *Alexander
> Korotkov
> *Sent:* Sunday, July 01, 2012 8:33 AM
> *To:* PostGIS Development Discussion
> *Subject:* Re: [postgis-devel] New node splitting algorithm for GiST
>  On Sat, Jun 30, 2012 at 10:59 PM, Paul Ramsey <pramsey at opengeo.org>wrote:
>> No progress, still an "item of interest" in my list of things I might
>> do. If you prepare a compile-time conditional patch, I'd be interested
>> in reviewing and applying it.
> OK, it's here.
> Just an small example. Without patch.
>  test=# create index geonames_idx on geonames using gist (point);
> CREATE INDEX
> Time: 113796,848 ms
> test=# explain (analyze, buffers) select * from geonames where point &&
> 'BOX(34.4671 126.631,34.5023 126.667)'::box2d::geometry;
>                                  QUERY PLAN
>  Index Scan using geonames_idx on geonames  (cost=0.00..14.05 rows=2
> width=128) (actual time=0.589..0.876 rows=11 loops=1)
>    Index Cond: (point &&
> '0103000000010000000500000016FBCBEEC93B4140AAF1D24D62A85F4016FBCBEEC93B4140A69BC420B0AA5F40F163CC5D4B404140A69BC420B0AA5F40F163CC5D4B404140AAF1D24D62A85F4016FBCBEEC93B4140AAF1D24D62A85F40'::geometry)
>    Buffers: shared hit=26
>  Total runtime: 0.927 ms
> (4 rows)
> With patch.
> test=# create index geonames2_idx on geonames2 using gist (point);
> CREATE INDEX
> Time: 118382,076 ms
> test=# explain (analyze, buffers) select * from geonames2 where point &&
>                                  QUERY PLAN
>  Index Scan using geonames2_idx on geonames2  (cost=0.00..22.40 rows=4
> width=128) (actual time=0.209..0.225 rows=11 loops=1)
>    Buffers: shared hit=11
>  Total runtime: 0.276 ms
> (4 rows)
> With best regards,
> Alexander Korotkov.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120701/f5b25f99/attachment.html>
